$185.00
Article number: Rims
The Belgium G / Emporia is HED's take on the modern gravel rim. Tubeless compatible, extra wide, and the reliability and durability of Belgium's, these are probably the best alloy rims on the market.
Perfect for a training wheelset you can beat up, a travel wheelset, or just a wheel upgrade from stock wheels without breaking the bank.
HED Belgium G alloy rims make any custom wheel build that much sweeter. With 30mm external and 25mm internal widths, you can add tire volume, smoothness, and rolling speed to any bike or hub set.
All Belgium rims feature a welded rim joint, and are drilled for a standard presta valve.  Spoke drilling is down the centerline of the rim (not offset).
Wheel Building
BELGIUM G DISC RIM
 Weight ~453g
 Material Aluminum
 Hole Count 24 / 28 / 32
 External Rim Width 30 mm
 Internal Rim Width 25 mm
 Rim Depth 24 mm
 Recommended Tire Width 700 x 32 mm
 Tubeless Compatible Yes
 ERD 593 mm
 Max Tire Pressure 80 psi
