HED Belgium G Disc Brake Rim
Article number: | Rims |
The Belgium G / Emporia is HED's take on the modern gravel rim. Tubeless compatible, extra wide, and the reliability and durability of Belgium's, these are probably the best alloy rims on the market.
Perfect for a training wheelset you can beat up, a travel wheelset, or just a wheel upgrade from stock wheels without breaking the bank.
HED Belgium G alloy rims make any custom wheel build that much sweeter. With 30mm external and 25mm internal widths, you can add tire volume, smoothness, and rolling speed to any bike or hub set.
All Belgium rims feature a welded rim joint, and are drilled for a standard presta valve. Spoke drilling is down the centerline of the rim (not offset).
Wheel Building
BELGIUM G DISC RIM | |
Weight | ~453g |
Material | Aluminum |
Hole Count | 24 / 28 / 32 |
External Rim Width | 30 mm |
Internal Rim Width | 25 mm |
Rim Depth | 24 mm |
Recommended Tire Width | 700 x 32 mm |
Tubeless Compatible | Yes |
ERD | 593 mm |
Max Tire Pressure | 80 psi |
