Gelu S-1 Saddle
Article number: | 002-02-02 |
The S-1 is often seen as the most versatile saddle in the Gelu line, as the overall shape of the saddle allows the rider to change positions with ease, and remain perfectly comfortable. This along with the central cutout to alleviate pressure makes this one of the most comfortable carbon saddles available. The S-1 supports riders up to 115 kgs (253 lbs), and just like the J series, the S-1 is orthopedically certified!
Weight | ~66g (Matte 3k version) |
Construction | Carbon |
Widths | 122 mm |
Length | 270 mm |
Nose Width | 37 mm |
Rail Diameter | 7 x 9 mm |
Use | Road, Mtn, Gravel, Cyclocross |
Rider Weight Limit | 115 kgs (253 lbs) |
