Gelu K-4 Saddle
$405.00
Article number: 002-02-02
The K-4 is the slightly heavier stiffer brother of the K-3. The very small weight gain of the K-4 opens the door, allowing you to use it for anything from road riding, to mountain biking, and anything in between. The central cutout is slightly smaller than on other models, but still provides adequate pressure relief for sensitive areas. At 59 grams, the K-4 is still feather light in the world of carbon saddles, and yet it can also accomodate riders weighing up to 253lb's. The K-4 saddle is one of the many reasons why the K series has become so popular amongst cyclists.
 Weight ~59g
 Construction Carbon
 Widths 122 mm
 Length 242 mm
 Nose Width 38 mm
 Rail Diameter 7 x 9 mm
 Use MTB, Gravel, Road
 Rider Weight Limit 115 kgs (253 lbs)
