Gelu J-3 Saddle
$425.00
Article number: 002-02-02
The J-3 is Gelu's modern take on classic spring saddles. Instead of steal springs Gelu has meticulously crafted two carbon springs: a longitudinal spring and a transverse spring. The result is a full carbon saddle that absorbs all the bumps and vibrations you normally feel, and leaves you with a smooth and comfortable ride. The most incredible part is that this is the only spring saddle in the world that is under 100 grams. The cutout also ensures the total absence of unnecessary pressure. Just like the K series, the J-3 is orthopedically certified!
 Weight ~87g (Matte 3k version)
 Construction Carbon
 Widths 126 mm
 Length 250 mm
 Nose Width 45 mm
 Rail Diameter 7 x 9 mm
 Use Road
 Rider Weight Limit 85 kgs (187 lbs)
