Gelu Carbon Straight Seatpost
Article number: | 002-02-02 |
Since 2013 Gelu has been perfecting the craft of hand made carbon components. The Gelu carbon seat post is a thing of beauty. Handmade in Portugal with the rest of their line, it is simple, yet beautiful. A UD carbon tube, with an aluminum head that is seamlessly bonded onto the post. The clamp and rocker are constructed from carbon, and both are held together with two titanium bolts and 2 aluminum barrel nuts. In addition these seat posts boast an impressive weight limit of 115kg (253lb), which is far higher than many carbon seat posts on the market.
27.2 mm | 31.6mm | |
Weight | ~107g | ~119g |
Saddle Rails | 7 x 7 / 7 x 9 | |
Max Torque | 3Nm(post) / 2.5Nm(rails) | |
Max Weight | ~115 kg (253lbs.) |
