FSE V.2 Carbon Tubeless Road Rims
$500.00
Filament Spun Evolution, a next-generation carbon rim manufacturer, uses a precise and efficient computer-controlled manufacturing system to create rims that are stronger, stiffer, lighter, and less expensive than similar rims from other manufacturers. Traditional rim manufacturing methods are highly labor intensive, resulting in increased production costs and potential for defects which can greatly affect rim performance and longevity. Backed by over 5 years of research and development, FSE's proprietary manufacturing and quality control processes ensure consistent, near-perfect production over their entire impressive rim catalog. FSE's precisely-controlled production process evenly applies resin to each carbon strand to ensure a lightweight, void-free carbon cross-section. Beyond their own internal testing, FSE rims are UCI tested and approved for the highest levels of competition.
FSE's "version 2" series of rim brake road carbon tubeless rims are available in three distinct depths to match just about any riding style, terrain, and conditions. Compared to previous versions of their road tubeless rims, these are 10-15 grams lighter with a slight increase in the depth and width of each aerodynamic profile. Each rim features a matte 3k weave finish with permanent  ghosted logos. Keeping with current industry standards, all FSE rims feature wide aerodynamic profiles for the best possible performance on the road. With the application of rim tape, a valve, and sealant, FSE's tubeless rim bed allows the mounting of road tubeless tires in widths from 25-32mm.
Wheel Builds
FSE Tubeless Road rims are designed for use with standard external spoke nipples. FSE rims do not include rim tape or tubeless valves; these must be purchased separately. 27-29mm wide tubeless tape and appropriate length (48-75mm) tubeless valves are recommended,
Our professional wheel builders are happy to advise on the best possible combination of rims, hubs, and spokes for a cyclist's individual needs. Please contact us directly for custom wheel quotes.
DepthWeightInternal WidthExternal WidthERD
32mm415 grams20 mm27.2 mm573 mm
46mm455 grams20 mm27.4 mm553 mm
58mm510 grams20 mm27.7 mm527 mm
Tire Compatibility700c clincher (ISO 622), tubeless compatible
Recommended Tire Width25-32c
Materialcarbon fiber
Finish3K matte
Brake Compatibilityrim brake
Recommended Brake PadsSwissStop Black Prince
Rider Weight Limit230 lbs (105 kg)
Tubeless Rims
Style:
Road
Size:
700c
3K Matte
Fits:
20h
Fits:
24h
Carbon
