FSE V.2 Carbon Tubeless Road Disc Rims
FSE
$500.00
Filament Spun Evolution, a next-generation carbon rim manufacturer, uses a precise and efficient computer-controlled manufacturing system to create rims that are stronger, stiffer, lighter, and less expensive than similar rims from other manufacturers. Traditional rim manufacturing methods are highly labor intensive, resulting in increased production costs and potential for defects which can greatly affect rim performance and longevity. Backed by over 5 years of research and development, FSE's proprietary manufacturing and quality control processes ensure consistent, near-perfect production over their entire impressive rim catalog. FSE's precisely-controlled production process evenly applies resin to each carbon strand to ensure a lightweight, void-free carbon cross-section. Beyond their own internal testing, FSE rims are UCI tested and approved for the highest levels of competition.
FSE's "version 2" series of disc-specific carbon tubeless rims are available in three distinct depths to match just about any riding style, terrain, and conditions. Compared to previous versions of their road disc rims, these are 10-15 grams lighter with a slight increase in the depth and width of each aerodynamic profile. Each rim features a matte 3k weave finish with permanent  ghosted logos. Keeping with current industry standards, all FSE rims feature wide aerodynamic profiles for the best possible performance on the road. With the application of rim tape, a valve, and sealant, FSE's tubeless rim bed allows the mounting of road tubeless tires in widths from 25-32mm.
Wheel Builds
FSE Tubeless Road Disc rims are designed for use with standard external spoke nipples. FSE rims do not include rim tape or tubeless valves; these must be purchased separately. 27-29mm wide tubeless tape and appropriate length (48-75mm) tubeless valves are recommended,
Our professional wheel builders are happy to advise on the best possible combination of rims, hubs, and spokes for a cyclist's individual needs. Please contact us directly for custom wheel quotes.
DepthWeightInternal WidthExternal WidthERD
32mm395 grams20 mm27.2 mm573 mm
46mm435 grams20 mm27.4 mm553 mm
58mm495 grams20 mm27.7 mm527 mm
Tire Compatibility700c clincher (ISO 622), tubeless compatible
Recommended Tire Width25-32c
Materialcarbon fiber
Finish3K matte
Rider Weight Limit230 lbs (105 kg)
