Sale
FSE Carbon Tubular Road Rims
$450.00 $315.00
$450.00
(You save $135.00 )
Sale / Closeout
Filament Spun Evolution, a next-generation carbon rim manufacturer, uses a precise and efficient computer-controlled manufacturing system to create rims that are stronger, stiffer, lighter, and less expensive than similar rims from other manufacturers. Traditional rim manufacturing methods are highly labor intensive, resulting in increased production costs and potential for defects which can greatly affect rim performance and longevity. Backed by over 5 years of research and development, FSE's proprietary manufacturing and quality control processes ensure consistent, near-perfect production over their entire impressive rim catalog.
While generally more of an issue on carbon clincher rims, the weak point of traditional carbon rims has nearly always been in the braking surface. Heavy braking on long descents will quickly soften the resin that holds the fibers together, often resulting in dangerous, catastrophic failure. Through partnerships with university research departments, chemical corporations, and research institutes, FSE was able to develop a new, high thermal glass point resin that is stable past 240 degrees Celsius. Additionally, FSE's precisely-controlled production process evenly applies this resin to each carbon strand to ensure a lightweight, void-free carbon cross-section. Beyond their own internal testing, FSE rims are UCI tested and approved for the highest levels of competition.
FSE's series of carbon tubular rims are available in a wide range of depths to match just about any riding style, terrain, and conditions. For those who are willing to sacrifice the convenience of clincher tires, tubulars offer improved safety and top-level race performance with the lowest possible wheel weights. Keeping with current industry standards, all FSE rims feature wide aerodynamic profiles for the best possible performance on the road. The 25mm rims are finished with black die-cut logos, while all the deeper rims are manufactured with permanent "ghosted" logos.
Custom Wheel Builds
While we offer stock builds with FSE rims (such as this FSE/Carbon-Ti wheelset), our professional wheel builders are happy to advise on the best possible combination of rims, hubs, and spokes for a cyclist's individual needs. Please contact us directly for custom wheel quotes.
DepthWeightExternal WidthERD
35mm335 grams26.7 mm575 mm
Tire Compatibility28" tubular
Recommended Tire Width23-28c
Materialcarbon fiber
Finish3K matte
Brake Compatibilityrim brake
Recommended Brake PadsSwissStop Black Prince
Rider Weight Limit230 lbs (105 kg)
Tubular Rims
3K Matte
Fits:
20h
Fits:
24h
Style:
Road
Carbon
