Sale
FSE Carbon Tubeless Road Rims
$500.00 $375.00
$500.00
(You save $125.00 )
Filament Spun Evolution, a next-generation carbon rim manufacturer, uses a precise and efficient computer-controlled manufacturing system to create rims that are stronger, stiffer, lighter, and less expensive than similar rims from other manufacturers. Traditional rim manufacturing methods are highly labor intensive, resulting in increased production costs and potential for defects which can greatly affect rim performance and longevity. Backed by over 5 years of research and development, FSE's proprietary manufacturing and quality control processes ensure consistent, near-perfect production over their entire impressive rim catalog.
Industry wide, the weak point of traditional carbon clincher rims has nearly always been in the braking surface. Heavy braking on long descents will quickly soften the resin that holds the fibers together, often resulting in dangerous, catastrophic failure. Through partnerships with university research departments, chemical corporations, and research institutes, FSE was able to develop a new, high thermal glass point resin that is stable past 240 degrees Celsius. Additionally, FSE's precisely-controlled production process evenly applies this resin to each carbon strand to ensure a lightweight, void-free carbon cross-section. Beyond their own internal testing, FSE rims are UCI tested and approved for the highest levels of competition.
While slightly heavier (about 20 grams per rim), these tubeless-ready rims share all the same features of FSE's traditional clincher rims. With the application of rim tape, a valve, and sealant, FSE's tubeless rim bed allows the mounting of road, gravel, and cyclocross tubeless tires. Keeping with current industry standards, all FSE rims feature wide aerodynamic profiles for the best possible performance on the road. Each rim features a matte 3k weave finish with permanent "ghosted" logos.
Custom Wheel Builds
While we offer stock builds with FSE rims (such as this FSE/Carbon-Ti wheelset), our professional wheel builders are happy to advise on the best possible combination of rims, hubs, and spokes for a cyclist's individual needs. Please contact us directly for custom wheel quotes.
If you are looking for a size not listed please see the new rims here.
DepthWeightInternal WidthExternal WidthERD
25mm410 grams17 mm25.2 mm590 mm
45mm480 grams18 mm26.7 mm552 mm
Tire Compatibility700c clincher (ISO 622), tubeless compatible
Recommended Tire Width23-32c
Materialcarbon fiber
Finish3K matte
Brake Compatibilityrim brake
Recommended Brake PadsSwissStop Black Prince
Rider Weight Limit230 lbs (105 kg)
Tubeless Rims
3K Matte
Size:
700c
Fits:
20h
Fits:
24h
Style:
Gravel
Style:
Road
Carbon
