The FSA SL Angular Contact Bearing is a great example of an inexpensive way to shed a couple grams from your vital moving parts. Substituting an aluminum cup for the bulky outer race, FSA has dropped over 25% of the weight from a traditional all steel bearing. This significantly lighter bearing still has two steel races and ball bearings, they have just been put on a serious diet. To slim them down FSA had to eliminate all superfluous material, without the bulky steel outer race you get a bearing that performs flawlessly at fighting weight. Since a headset sees little rotation throughout its life it is a perfect candidate for a bit of gram shaving. If you're trying to build the lightest bike possible, a set of FSA SL Headset Bearings are the perfect choice for your next project.
Bearing (Steer Tube Diameter Outer Angle x Inner Angle) |
Bearing Dimensions (IDxODxHeight) |
1-1/8" 36°x45° | 30x41x6.5mm |
1-1/8" 45°x45° | 30x42x8mm |
1-1/4" 45°x45° | 34x47x7mm |
1-1/2" 36°x45° | 52x40x8mm |
Weights | |
1-1/8" 36°x45° | 13.1 grams |
1-1/8" 45°x45° | 14.1 grams |
1-1/4" 45°x45° | 16.9 grams |
1-1/2" 36°x45° | 22.0 grams |
