Producing cycling components of every variety, FSA has been supporting cyclists with their widely varying catalog of parts for decades. Continued investment in their component portfolio demonstrates their dedication to the industry and their commitment to every cyclist from the enthusiast to the professional.
With the K-Wing Compact Carbon Handlebar, FSA has created a bar that has gained popularity with riders for its multitude of hand positions and unique ergonomics. This compact bar includes several particular features that set it apart from traditional drop bars. The first and most noticeable is the raised flat top; with a slight back sweep, aerodynamic profile, and ergonomic design this raised portion offers a more relaxed position and provides ample space to rest your hands. The bar tops also feature slight cut-out like shaping on either end, providing a nice perch for the palms when riding positioned at the widest part of the bar tops. The compact drops allow easy and fast swapping between hand positions including smooth transitioning from the bar tops to the drops. In addition, the compact 125mm drop and 80mm reach allows riders to maintain hand position regardless of which lever or button they need to access, eliminating the sometimes awkward re-positioning needed on some standard drop bars. Easier access to the controls means better control, and elimination of over-exaggerated hand positioning greatly improves comfort. Enlarged internal cable routing slots allow easy routing of both brake and derailleur cables and also work with electronic shift systems, helping to maintain an ultra-clean looking cockpit.
Made from a unidirectional carbon fiber and kevlar composite mixture, the K-Wing offers stiffness, durability, and vibration damping in spades. All clamping zones of the bar are textured to ensure a slip-free interface regardless of how rough the terrain gets. With sharp white and red logos and a glossy finish over the subtly marbled carbon outer-layer, FSA adds just the right amount of "eye catching" aesthetic features. The distinct FSA K-Wing handlebar features the perfect balance of performance, comfort, and ergonomics, ideal for riders who spend lots of time in the saddle.
Stem Clamp Diameter | 31.8 mm |
Reach | 80 mm |
Drop | 125 mm |
Back Sweep | 2° |
Material | UD Carbon Fiber, Kevlar |
Finish | Carbon Gloss |
Weights | |
38 cm | 231 grams |
40 cm | 237 grams |
42 cm | 248 grams |
44 cm | 254 grams |
