FSA Gossamer Compact Handlebar
$66.40
The Gossamer Compact handlebar by FSA boasts a design influenced by their high-end models, featuring a shallow 125mm drop and a short 80mm reach, perfectly tailored for modern shifters. Rider comfort is prioritized with its flattened top section, providing a convenient hand resting platform. Crafted from double butted and tapered 6066 Aluminum, it balances strength and weight efficiency. Shot peening enhances fatigue resistance, and its wide center section offers ample accessory mounting space. Finished in a sleek sand-blasted black anodized coating, it measures 110mm wide at the center. Perfect for cyclists seeking both performance and functionality, measured from the dropouts, not hoods.
Measurements (C - C)
 Dropouts 38 cm 40 cm 42 cm 44 cm
 Hoods 361.5 mm 381.5 mm 401.5 mm 421.5 mm
 Weight ~310g
 Reach 78 mm
 Drop 123.2 mm
 Outward Bend 2° degrees
 Stem Clamp Diameter 31.8 mm
 Material 6066 Aluminum, Double Butted
