FSA Energy Compact SCR Handlebar
$102.80
Article number: FitWorks
FSA's Energy Compact alloy handlebars blend strength, ergonomics, and functionality. Crafted from robust 7050 aluminum, strategically varying wall thickness ensures reinforcement where needed, optimizing weight. The bars feature a comfortable 34mm flattened top section and a spacious center for accessories. With a shallow 125mm drop and 80mm reach, they offer easy control and a comfortable riding position, promoting improved airflow. Sandblasted texture enhances grip, and the sleek bead-blasted black finish with polished sections is compatible with ACR and SCR systems. The outward bend is set at 4°, measured from the dropouts, not hoods.
Measurements (C - C)
 Dropouts 38 cm 40 cm 42 cm 44 cm
 Hoods 361.5 mm 381.5 mm 401.5 mm 421.5 mm
 Weight ~260g ~264g ~269g ~275g
 Reach 78 mm
 Drop 123.2 mm
 Outward Bend 4° degrees
 Stem Clamp Diameter 31.8 mm
 Material 7050 Aluminum, Double Butted
