FSA A-Wing AGX Alloy Handlebar
FSA's AGX components are ideal for Adventure, Gravel, and Cyclocross enthusiasts, blending advanced carbon composite and metal alloy technology with cutting-edge manufacturing. The A-Wing Pro alloy handlebar, designed for these pursuits, features flared drops for control during descents, showcasing FSA's alloy expertise. With Aerodynamic Integrated Cable Routing (ACR) and sculpted contact points for comfortable riding, it prioritizes ergonomics. The handlebar has a 121mm drop, 88mm reach, 15° outward bend, and 2.5mm rise. Finished in bead-blasted anodized black, it weighs just 296 grams (420mm version), measured from the hoods, not dropouts.
Measurements (C - C) | ||||
Dropouts | 46.8 cm | 48.8 cm | 50.8 cm | |
Hoods | 42 cm | 44 cm | 46 cm | |
Reach | 87.4 mm | 88.6 mm | 89.8 mm | |
Weight | ~296g | ~304g | ~313g | |
Outward Bend | 15 degrees | |||
Drop | 120.7 mm | |||
Stem Clamp Diameter | 31.8 mm | |||
Material | Aluminum |
