Feedback Sports Velo Wall Post
Article number: | 33-03-05 |
Feedback Sports products are guaranteed from defects in materials and manufacturing under a limited lifetime warranty.
If "leaning the bike against a wall" is your current storage solution, Feedback Sports has an upgrade for you. The Velo Wall Post is about a simple as it gets; a foldable 12" supported post from which you can hang your bicycle by its saddle, with room to spare for wheels, tires, and other accessories. Soft rubber inserts protect the finish of any parts that contact the post, and the base includes a lock port for added security when needed. When not in use, the Velo Wall Post folds up neatly against the wall. The base is mounted to a drywall stud or other secure structure via a pair of screw holes. Two 2" wood screws are included.
Load Capacity | 50 lbs (22.7 kg) |
Mounting Area | 7.25″ x 2.5″ (184 mm x 64 mm) |
Useable Length | 12″ (305 mm) |
Dimensions | 18.5 x 4 x 3.25" (47 x 10 x 8 cm) |
