Feedback Sports Team Edition Tool Kit
$300.00
Article number: 33-02-01
This Team Edition Tool Kit features 19 professional-grade tools to perform 25 separate bicycle maintenance and repair functions - an excellent investment for hobbyists, racers, and dedicated race mechanics. This medium-size tool set includes the most common tools needed for servicing modern bicycles and their components, all housed in a durable and waterproof TPU-coated zippered nylon case. The case includes a support rod for hanging the case from a repair stand or wall hook, and includes slots for Feedback's T-Handle Wrench Set as an add-on option.
Contents
Fixed 3-Way Wrench - Torx T25/27/30
Fixed 3-Way Wrench - Hex 2/2.5/3mm
Fixed 3-Way Wrench - Hex 4/5/6mm
L-Handle Hex Wrench - 8mm
L-Handle Hex Wrench - 10mm
Screwdriver - #0 Phillips w/ Crank Arm Cap Tool
Screwdriver - #2 Phillips
Screwdriver - 6mm Flathead
Valve Core Wrench
Spoke Wrench w/ Valve Extender Tool
Chain Pin Press Tool
Rotor Truing Fork
Steel Core Tire Levers w/ Brake Pad Spreaders (2)
Pedal and Axle Nut Wrench - 15mm
Bottom Bracket and Cassette Lockring Wrench
Cassette Pliers
Cable and Housing Cutter
Dual Sided Pick
