Feedback Sports T-Handle Wrenches
$20.90
Article number: 32-01-03
Arguably the flagship of Feedback Sports' line of bicycle tools, this series of seven T-Handle hex wrenches is extremely practical, allowing for a plethora of adjustments on modern bicycles. Designed specifically for bicycle repair and nearly half the size of similar automotive T-Handles, each of these compact wrenches is optimized for necessary leverage and ease of use. Tool ends on both the shaft and handles allow for high and low torque applications. Each of these T-handle wrenches are manufactured from professional-grade S2 tool steel.
Feedback's T-handle wrenches are available in individual sizes, as well as a complete seven-piece kit . The kit includes a nylon case coated in durable, water-resistant thermoplastic polyurethane, with a fold-up frame and a mesh pocket for additional storage.
T-Handle Sizes
2 mm hex2.5 mm hex
3 mm hex
4 mm hex
5 mm hex
6 mm hex
T25 torx
Wrench Sizes 2, 2.5, 3, 4, 5, 6, T25
Material S2 tool steel
Case Dimensions 8” x 6.75” x 1.75” (20 x 17 x 4.4cm)
Tool Length 4 - 5" (10 - 13 cm)
Tool Width 2.5 - 3.75 (6.5 - 9.5 cm)
