Feedback Sports Rotor Truing Fork
Article number: | 33-01-02 |
Often, the best solution for a bent or warped rotor is replacement. However, if a replacement is not available, or if the warp is slight, the rotor may be manually trued. Feedback's rotor truing tool features a simple, time-tested design; a long slot for correcting the rotor at the braking surface, and a short slot for tweaking the spokes of the rotor. This truing fork is manufactured from forged steel and nickel plated for extra durability.
