Feedback Sports 3-Piece Screwdriver Set
Article number: | 33-01-02 |
Feedback Sports' screwdriver set supplies the most common sizes needed for modern bicycle service, with features to set them apart from the tools at your local hardware store. The screwdriver shafts are manufactured from chromium-vanadium steel, and are each equipped with a handy magnetic tip. The comfortable polymer plastic grips are coated in rubber for extra security, and the smallest screwdriver is cleverly equipped with a Shimano HTII crank fixing bolt tool. The included sizes are Phillips #0, Phillips #2, and a medium 6mm flathead.
