Feedback Sports 15mm Pedal and Axle Nut Wrench
$26.50
Article number: 33-01-02
This two-sided wrench is manufactured from forged and nickel-plated steel and designed with a length of 10.5" for extra leverage. One end of the tool is designed for removal of traditional pedal spindles with 15mm wrench flats, while the other end is equipped with a 12-point closed socket for removal and installation of 15mm axle nuts. The pedal wrench side features a double-sided angled head to allow proper mechanical advantage regardless of spindle orientation.
