Far And Near Ultegra R8000 Brake Hoods
$29.00
Article number: 026-03-06
Each set comprises two hoods, one for the left and one for the right, meticulously designed to fit Shimano Ultegra R8000 11-speed levers.
INSTALLATION
Please note that these hoods are not compatible with Shimano Ultegra (8020 / 8050 / 8070) series 11-speed shift/brake levers.
Compatibility Shimano Ultegra R8000 Shift Levers
Weight ~53g (pair)
