Far And Near Ultegra Di2 6770 Brake Hoods
$30.00
$24.00
* Unit price: $24.00 /
Article number: 14-04-03
Each set comprises two hoods, one for the left and one for the right, meticulously designed to fit Shimano Ultegra 6770 Di2 10-speed levers.
INSTALLATION
Please note that these hoods are not compatible with Shimano Ultegra 6700 series 10-speed shift/brake levers.
Compatibility Shimano Ultegra 6770 Di2 Shift Levers
Weight ~55g (pair)
