Far And Near Ultegra 6800 Brake Hoods
Article number: | 026-04-04 |
Each set comprises two hoods, one for the left and one for the right, meticulously designed to fit Shimano Ultegra 6800 11-speed levers.
INSTALLATION
Please note that these hoods are not compatible with Shimano Ultegra Di2 6870 series 11-speed shift/brake levers.
Compatibility | Shimano Ultegra 6800 Shift Levers |
Weight | ~49.5g (pair) |
