Far And Near Ultegra 6700 Brake Hoods
$25.00
$20.00
* Unit price: $20.00 /
Article number: 026-03-04
Each set comprises two hoods, one for the left and one for the right, meticulously designed to fit Shimano Ultegra 6700 10-speed levers.
INSTALLATION
Please note that these hoods are not compatible with Shimano Ultegra 6770 (Ultegra Di2) series 10-speed shift/brake levers.
 Compatibility Shimano Ultegra 6700 Shift Levers
 Weight ~60g (pair)
