Far And Near SRAM Red22 / Force22 Brake Hoods
Article number: | 026-04-02 |
Each set includes left and right hoods, meticulously designed for SRAM Red22 / Force22 11-speed mechanical groups.
INSTALLATION
Please note that these hoods are not compatible with SRAM hydraulic series 11-speed shift/brake levers.
Compatibility | SRAM 11-speed mechanical Shift Levers |
Weight | ~53g (pair) |
