Far And Near SRAM 10spd Brake Hoods
Article number: | 026-04-01 |
Each set includes left and right hoods, meticulously designed for older (2012 and previous) SRAM Red, Force and Rival 10 speed levers.
INSTALLATION
Compatibility | SRAM Red, Force and Rival 10-speed Shift Levers |
Weight | ~53g (pair) |
