Far And Near SRAM 10spd Brake Hoods
$25.00
$18.00
* Unit price: $18.00 /
Article number: 020-04-01
Each set includes left and right hoods, meticulously designed for older (2012 and previous) SRAM Red, Force and Rival 10 speed levers.
INSTALLATION
 Compatibility SRAM Red, Force and Rival 10-speed Shift Levers
 Weight ~53g (pair)
