$25.00
$20.00
* Unit price: $20.00 /
Article number: 026-03-02
Each set comprises two hoods, one for the left and one for the right, meticulously designed to fit Shimano 105 (5600), Ultegra (6600) and Ultegra SL 10-speed levers.
INSTALLATION
 Compatibility Shimano 105 (5600) / Ultegra 6600 Levers
 Weight ~58g (pair)
