Categories
Offering an axle to fit the most popular thru axle designs Far and Near has crafted a thru axle that every rider can depend on. Foregoing a lever that can get snagged or catch on rough terrain Far and Near has tooled 6 mm allen wrench flats into the head of their axles. This creates a marvelously low profile design that maintains secure fitment of the wheel to the frame. Machined from 7075 Aluminum and then anodized to rich hues to match all other Far and Near components these axles will look at home on any mountain bike. Built for peace of mind and sturdy engagement this axle won’t let you down even under the most strenuous of riding conditions. Add a little color to your bike without emptying your wallet with Far and Near Thru Axles.
Model | Interface | Length | Thread Pitch | Thread Length | Weight |
E-thru | Flat | 169mm | 12x1.5mm | 18mm | 39 grams |
E-Thru Boost | Flat | 180mm | 12x1.5mm | 18mm | 42 grams |
Maxle | Flat | 172mm | 12x1.75mm | 20mm | 41 grams |
Maxle Boost | Flat | 182mm | 12x1.75mm | 20mm | 42 grams |
Scott | Flat | 168mm | 12x1mm | 17mm | 40 grams |
Material | 7075 aluminum | ||||
Hub Compatibility | TA 12x142 TA 12x148 Boost | ||||
Tool Fitting | 6mm Hex | ||||
Recommended Torque | 10Nm |
