$10.00
$6.50
* Unit price: $6.50 /
Article number: 020-02-06
Elevate the style of your 11-speed Campagnolo derailleur with Far and Near's pulley bolts. These bolts are expertly designed with a broad 12mm head, distributing clamping pressure over a larger area of Campagnolo's carbon derailleur cage plates. Crafted from lightweight yet robust 7075 aluminum, they come in a striking array of six anodized colors.
INSTALLATION
To install Far and Near pulley bolts, you'll need a T25 Torx wrench. If you have access to a torque wrench, we recommend tightening them to 4 Nm. Each bolt incorporates pre-treated threads to prevent accidental loosening.
*Please note that these pulley bolts are compatible only with pre-2011 derailleurs.
 Weight ~2g (per set)
 Compatibility 11spd Super Record / Record / Chorus
