Far and Near Front Thru Axle
$39.00
Article number: 020-05-01
Availability: In stock (6)
Far and Near provides a comprehensive range of components to meticulously coordinate every element of your next bike build. Their commitment to simplicity and functionality ensures that each part is not only elegant but also highly reliable.
One of their standout offerings is the low-profile thru axle, available in the two most common designs for Fox and Rock Shox. Crafted from robust 7075 Aluminum and anodized in rich hues, these axles feature a sturdy head and deep 6mm allen wrench grooves, ensuring a secure fit once installed. Additionally, their tapered design in the center reduces weight without compromising strength, making these axles capable of withstanding the most demanding riding conditions.
Model Interface Length Pitch Thread Length Weight
Fox Flat 146 mm 14 x 1.5 mm 13 mm ~37g
Rock Shox Flat 147 mm 15 x 1.5 mm 11 mm ~37g
Fox Boost* Flat 155 mm 14 x 1.5 mm 13 mm ~39g
Rock Shox Boost* Flat 155 mm 15 x 1.5 mm 11 mm ~39g
 Material 7075 Aluminum
 Tool Fitting 6 mm Hex
 Hub Compatibility T/A 15 x 100  T/A 15 x 110*
 Recommended Torque 10Nm
