$30.00
Article number: 026-04-03
Each set includes left and right hoods, meticulously designed for Shimano Dura-Ace R9100 11-speed levers.
INSTALLATION
Please note that these hoods are not compatible with Shimano Dura-Ace (R9120 / R9150 / R9170 series) shift/brake levers. Additionally, they are not compatible with any Di2 shift levers.
Compatibility Shimano D/A R9100 Shift Levers
Weight ~53g (pair)
