Far And Near Dura Ace 7900 Brake Hoods
$25.00
Article number: 020-04-06
Availability: In stock (3)
Each set includes left and right hoods, meticulously designed for Shimano Dura-Ace 7900 10-speed levers.
INSTALLATION
Compatibility Shimano Dura-Ace 7900 Shift Levers
Weight ~52g (pair)
