Far And Near Dura Ace 7900 Brake Hoods
Article number: | 026-04-06 |
Each set includes left and right hoods, meticulously designed for Shimano Dura-Ace 7900 10-speed levers.
INSTALLATION
Compatibility | Shimano Dura-Ace 7900 Shift Levers |
Weight | ~52g (pair) |
