Far And Near Campagnolo EPS Brake Hoods
Article number: | 026-05-04 |
Each set includes left and right hoods, meticulously designed for Campagnolo 11-speed EPS levers.
INSTALLATION
Compatibility | Campagnolo 11-speed EPS Levers |
Weight | ~55g (pair) |
