Far And Near Campagnolo 11spd Brake Hoods
Article number: | 026-05-06 |
Each set includes left and right hoods, meticulously designed for Campagnolo 11-speed Ergopower levers.
INSTALLATION
Compatibility | Campagnolo 11-speed Ergopower Levers |
Weight | ~47g (pair) |
