Far And Near 105 5700 Brake Hoods
Article number: | 026-03-03 |
Each set includes left and right hoods, meticulously designed for Shimano 105 5700 10-speed levers.
INSTALLATION
Compatibility | Shimano 105 5700 Shift Levers |
Weight | ~58g (pair) |
