Far And Near 105 5700 Brake Hoods
$25.00
$20.00
* Unit price: $20.00 /
Article number: 026-03-03
Each set includes left and right hoods, meticulously designed for Shimano 105 5700 10-speed levers.
INSTALLATION
 Compatibility Shimano 105 5700 Shift Levers
 Weight ~58g (pair)
