$9.00
Article number: 013-04-06
Add a personalized touch to your bike with Fair Wheel Bikes Tubeless Valves. Designed for both performance and style, these valves are an excellent addition to any tubeless-ready wheelset.​
Key Features:
  • Optimized Airflow:
    • The valve's plug end features a 5-hole channel, ensuring consistent and reliable airflow, particularly beneficial for riders using liners or high-particle sealants.
  • Integrated Valve Core Remover:
    • Each valve includes an aluminum cap that doubles as a Presta valve core remover, facilitating effortless sealant addition and valve maintenance.​​
  • Lightweight and Durable:
    • Crafted from high-quality aluminum, these valves weigh between 6g and g, minimizing additional weight on your setup.​​
  • Versatile Fit:
    • Engineered to provide a reliable seal, enhancing the performance and reliability of your tubeless system.​
  • Color Options:
    • Personalize your ride with color choices including Black, Blue, Orange, Red, and Gold.
  • Sold Individually:
    • Each valve is sold separately, enabling you to purchase the exact quantity needed for your setup.​​
Upgrade your tubeless system with Fair Wheel Bikes' Tubeless Valve and Valve Core Remover for a more efficient and personalized cycling experience.
 Weight per Valve ~6 g - 9g
 Valve Length 44 mm, 60 mm, 80 mm
 Material Aluminum, Brass, Rubber
