Fair Wheel Bikes Khamsin Titanium Stem
$219.45
Article number: 013-06-04
The Khamsin Ti stem is the sleeker (yet slightly heavier) brother of our Bajada stem. Unlike our other ti offering, this stem features one piece construction resulting in a smoother flowing aesthetic: no welds, and a more robust clampable portion for your handlebars.
TITANIUM BOLT UPGRADE: Run it as is, or pair it with black, blue, gold, or rainbow titanium hardware for increased weight savings and a uniform aesthetic. Follow the link here and select the color you want from the drop down menu and add to cart.
 Length 90 mm 100 mm 110 mm 120 mm
 Weight ~ ~150g ~ ~
 Stem Angle ± 7°
 Stack 43 mm
 Clamp Diameter 31.8 mm
 Steerer Diameter 1 - 1/8" (1.125mm)
 Max Torque 6Nm
 Recommended Use Road / Cyclocross / Gravel
 Material Stem Hardware
  Titanium Stainless Steel
