Extralite Ultrastar 4 Expander Plug
$32.00
Article number: 024-04-01
When every gram counts, go with Extralite. This exquisitely machined expander plug fits alloy or carbon steer tubes. Pair with standard M6 top cap bolts or Extralites Hypercap and hollow aluminum bolt combo for the lightest top cap setup possible. Suitable for Road, Cyclocross, X-Country, and Trail.
Make sure to select what size headset you have in the drop down menu above before adding to cart.
  1 - 1/8" 1 - 1/4"
Weight 4.7 grams 5.7 grams
Compatible Steerer Tube I.D.  23.3 to 25.2 mm 25 to 27.2 mm
Material 7075 T6 Aluminum
Torque 7-8Nm
Use Road, cross country
