Extralite Extrabolt 4.5 Brake Caliper Mounting Bolt Set
Article number: | 019-02-05 |
These super light titanium bolts from Extralite are exquisitely CNC machined and purposed built to mount brake calipers to your post mount mountain bike frame.The thread of the screws is laboriously rolled for higher strength and not cut or milled. Available in bare titanium or black with PVD coating.
Material | Titanium GRD5 |
Thread | M6 |
Tool Req. | Torx 30 |
Length of Thread | 8mm |
Length of Shaft | 16mm (with washer 15.2mm) |
Total Length | 21mm |
Max Torque | 7.8 Nm |
Weight | 9g per set |
