10% Off all 3T Components!
Extralite OctaRamp Road Chainrings
Sign Up For Our Newsletter
You're Signed Up!
Weight, CH2103 grams
Weight, MC98 grams
Weight, RC294 grams
Tooth Count, CH253/39
Tooth Count, MC52/36
Tooth Count, RC250/34
BCD110 mm (compact)
Material7075 T6 Aluminum
Extralite OctaRamp Road Chainrings CH2 110 BCD, 53/39 $169.00 In Stock
Extralite OctaRamp Road Chainrings MC 110 BCD, 52/36 $169.00 In Stock
Extralite OctaRamp Road Chainrings RC2 110 BCD, 50/34 $169.00 In Stock
Details
Extralite's series of road chainrings are available for compact 5-bolt, 110 BCD cranksets. These chainring sets offer the best possible compromise between lightweight design and accurate shifting performance. Elegantly machined and hard anodized in black, Extralite rings feature intelligent tooth profiling and shift ramps for chain engagement in 8 different crank positions for the quickest possible upshifts. These are compatible with all modern road drivetrains, including Shimano, Sram, and Campagnolo 10 and 11 speed systems (though they are NOT compatible with Campagnolo or Shimano 11 compact cranksets).
Options
RC2 - Road Compact - 50/34 - industry standard compact chainrings
CH2 - Compact High Ratio - 53/39 - a conversion chainring set to allow the higher gearing found on a 130 BCD crankset
MC - Medium Compact - 52/36 - a good balance between compact and standard sizes
