Extralite OctaOne Narrow-Wide Chainring
$65.00
Article number: 025-01-02
Extralite specializes in precision-engineered components designed for single-chainring setups, ensuring compatibility with standard BCD 104mm 4-bolt cranks. Their products seamlessly work with SRAM Eagle 12-speed and Shimano/SRAM 11-speed chains, with compatibility extending to older 10-speed and 9-speed chains. These components feature advanced design elements, such as phased teeth and integrated, threaded chainring bolt females, all crafted from hyper-accurate AL7075T6 CNC machined material. To top it off, these components boast exceptional durability, thanks to their "Hard-Black" anodized finish, complemented by laser-etched graphics for a sleek appearance.
 Material 7075-T6 Alloy
 Construction CNC
 Finish Hard Anodization
 Crank Compatibility 104 BCD
 Drivetrain Compatibility 12 / 11 / 10 / 9 Speed
Weight
 30T ~28g
 32T ~29g
 34T ~32g
 36T ~34g
 Compatible Chainring bolts (30t)  Wolf Tooth 10mm Chainring Bolts
