Extralite HyperWiz Front Hub For Rock Shox RS1
$275.00
SKU:
7E501D5A
Known for their extraordinarily lightweight components Extralite has been crafting premium parts for cyclists who desire to shed grams without sacrificing performance. In their twenty years of production Extralite has built a name for themselves with their perfect blending of gram saving and dependability. Constantly refining each product in their lineup Extralite has shown their dedication to producing some of the lightest bike components available. Each of their designs demonstrates their attention to detail and uncompromising drive to create the finest components on the market.
The HyperWiz is designed as a lighter alternative to the stock hub provided with the RockShox RS-1. This tasteful little amalgamation of carbon and aluminum features a hybrid axle, that like its hub shell is a combination of aluminum ends with a carbon center section. Due to its oversize end caps and 27mm axle the HyperWiz is remarkably stiff. This translates into less flex and keeps the front wheel tracking straight while railing through corners. Coming in at a scant 98 grams this is the lightest hub on the market compatible with the RS-1. If your looking to upgrade and shed a few grams from the front end the Extralite HyperWiz is the perfect hub to pair with your RS-1.
Please note that this hub is only compatible with the RockShox RS-1 fork. While the Boost 110 standard sounds similar the oversize encaps will prevent this hub from aligning with the drop outs.
Assembly
We recommend that any wheel built with the HyperWiz be assembled by an experienced wheelbuilder. We are happy to provide this service and can provide tips on rim and spoke selection if you so choose. Please contact us if you have any questions.
Weight98 grams
Material7075 TXX Aluminum
Carbon Fiber
Brake compatibility6 Bolt Disc
Bearings27.5mm x 37mm ABEC-5 (2)
Wheel Building Dimensions
Flange Diameter, Left43 mm
Flange Diameter, Right43 mm
Center to Left Flange26 mm
Center to Right Flange32 mm
