Extralite HyperStem 1.25
Article number: | 025-03-01 |
The Hyperstem 1.25 is tested well beyond the EN safety standard, Extralite is confident that the Hyperstem 1.25 can be used in a wide range of applications, including road and cross country. Each stem is expertly machined in 3D CNC from a solid block of 7075 Txx aluminum, resulting in the best possible stiffness-to-weight ratio. As the connection between the bicycle's handlebars and fork, the Hyperstem's 1.25 overall stiffness plays an essential role in conserving expended energy from the rider's upper body, through the handlebars, and into the main frame of the bicycle. This is especially important to consider in sprints and climbs - often the deciding factor in competition.
The Hyperstem 1.25 combines the same minimalist machine work and grade 5 titanium hardware in an exquisite design as the Hyperstem Stealth to shave as much weight off as possible. The Hyperstem 1.25 is an ideal option for the rider concerned with overall build weight. Easy to install with your current bar setup without unraveling any bar tape, the Hyperstem 1.25 uses a simple 2 piece, 4 bolt faceplate design and is compatible with all 31.8 mm clamp diameter bars and 1-1/4" steerer tubes. A T20 torx wrench is required for installation.
The Hyperstem is laser-etched prior to anodizing, which reduces the visual impact of the logo for a cool, understated black-on-black aesthetic.
GARMIN MOUNT: Extralite's new Garmin computer mount replaces the existing handlebar clamps on all current Hyperstems creating an aerodynamic and rigid platform for all Garmin models from the 1030 on down. Be sure when adding the Hyperstem Computer mount under related products to select the correct options you require (For Garmin or Wahoo and Gopro mounting options).
This sweet mount adds just 3.4g.
Material | 7075 Txx Aluminum |
Hardware | Grade 5 Titanium |
Stem Angles | +/-6° |
Clamp Diameter | 31.8 mm |
Steerer Clamp Diameter | 1-1/4" |
Stack | 38 mm |
Max Torque | 3 Nm |
Recommended Use | Road , Cyclocross , XC |
Weights | |
90 mm | 74 grams |
100 mm | 79 grams |
110 mm | 83 grams |
