Extralite HyperStem 1.25
$200.00
**All Hyperstem Stealth stems are coming with black bolts now**
Extralite has been manufacturing elite-level components for the cycling world since their beginning in 1995. Based out of Lodi, Italy, Extralite has crafted a name for themselves by designing and producing some remarkably lightweight components, staying true to their name. Each component produced by Extralite is not only incredibly light, but also is subject to rigorous testing to ensure safety and ultimate durability. The Hyperstem 1.25 is no exception; tested well beyond the EN safety standard, Extralite is confident that the Hyperstem 1.25 can be used in a wide range of applications, including road and cross country. Each stem is expertly machined in 3D CNC from a solid block of 7075 Txx aluminum, resulting in the best possible stiffness-to-weight ratio. As the connection between the bicycle's handlebars and fork, the Hyperstem's 1.25 overall stiffness plays an essential role in conserving expended energy from the rider's upper body, through the handlebars, and into the main frame of the bicycle. This is especially important to consider in sprints and climbs - often the deciding factor in competition.
The Hyperstem 1.25 combines the same minimalist machine work and grade 5 titanium hardware in an exquisite design as the Hyperstem Stealth to shave as much weight off as possible. The Hyperstem 1.25 is an ideal option for the rider concerned with overall build weight. Easy to install with your current bar setup without unraveling any bar tape, the Hyperstem 1.25 uses a simple 2 piece, 4 bolt faceplate design and is compatible with all 31.8 mm clamp diameter bars and 1-1/4" steerer tubes. A T20 torx wrench is required for installation.
The Hyperstem is laser-etched prior to anodizing, which reduces the visual impact of the logo for a cool, understated black-on-black aesthetic.
GARMIN MOUNT UPGRADE: Extralite's new Garmin computer mount replaces the existing handlebar clamps on all current Hyperstems creating an aerodynamic and rigid platform for all Garmin models from the 1030 on down. When you order the computer mount we will replace the standard handlebar clamps with the computer mount. If you would like to have the standard clamps as well please order an extra set here.  If you would like to run a Wahoo computer with your stem, just add this adapter here, which adds a mere 3.4 grams.
Material7075 Txx aluminum
HardwareGrade 5 titanium
Stem Angles+/-6°
Clamp Diameter31.8 mm
Steerer Clamp Diameter1-1/4"
Stack38 mm
Max Torque3 Nm
Recommended UseRoad , Cyclocross , XC
Weights
90 mm74 grams
100 mm79 grams
110 mm83 grams
Stems
Size:
90mm
Size:
100mm
Size:
110mm
Style:
Road
Style:
Mountain
Diameter:
31.8mm
Diameter:
1 - 1/4 in.
Aluminum
