Extralite HyperLefty 3 Disc Brake Front Hub
$211.00
The HyperLefty 3 hub, for Lefty 2.0, Ocho, and SuperMax forks, offers top performance and compatibility. It mounts directly to the fork, featuring an extra-wide spoke camber for optimal wheel stiffness and power transfer. Straight-pull spokes enhance rigidity and reduce weight, ensuring efficient power transfer. The oversized disc-side flange minimizes disc braking stress. Made from 7075 aluminum with black anodizing, it includes low-friction stainless steel bearings. Weighing 76 grams for the 24-hole version, it's perfect for weight-conscious riders. Available in 24 and 28 hole options.
WHEEL BUILDING
 Weight ~76g
 Spoke Holes 24h / 28h
 Bearing Size 6902 - (1) / 6805 - (1)
 Brake Interface 6-bolt
 Material 7075 Aluminum
 Compatibility Lefty 2.0, Ocho, Supermax (w/o Adapter)
--Wheel Building Dimensions--
  LEFT RIGHT
 Flange Diameter 53.6 mm 32 mm
 Center to Flange 27.0 mm 30.0 mm
 Spoke Hole Diameter 2.6 mm
