Extralite HyperGrips
Article number: | 025-01-02 |
Extralite's HyperGrip foam grips are the very lightest available for weight-conscious cross country racers; up to 50 grams may be saved over similar grip designs. The thick, featherweight EVA foam offers a surprising amount of comfort, with ergonomically friendly rounded edges and subtle embossed surface logos.
Black is now offered only in an MDN Version, Medium Density Neoprene. It is more comfortable, and slightly heavier.
To prevent slipping, Extralite HyperGrips must be installed with adhesive (not included). Common wood glue is recommended. Apply a small amount of adhesive to the inside of each grip, slide on and align position. The glue must be allowed to dry completely over a 24 hour period.
BLACK MDN | |
Weight | |
Grips | ~7.4g (per pair) |
Bar End Plugs | ~2.1g (per pair) |
Material | Medium Density Neoprene |
RED / WHITE | |
Weight | |
Grips | ~4.0g (per pair) |
Material | EVA Foam |
Handlebar Diameter | 22.2 mm |
